I'm adding a sub-panel on the 1st floor to clean up all the old circuits that run from the basement to the 1st floor. 1 1/4" EMT. I'd like to connect at the panel with a 90el but I'd need to cut one leg of the 90 to fit under the joists. The cut line looks like it's close to the bend radius so I might not be able to seat a set screw connector properly. Should I just hit the easy button and use a short piece of greenfield? See pics.
