silverknight
Has anyone out there used GREENLEE's #1731 Hydraulischer Stanzbugel punch? If you have, did you like it? Would you say it is a good tool, worth the money?
If you are looking for something easier than the normal pump hydraulic KO set, I highly recommend the Maxis punch that you use a drill to actuate. I used it quite a bit, it makes easy work of even large KOs in thick gauge steel. For lots of larger (4") holes in thick steel I would recommend a 120V drill, but the a few smaller holes in a typical panel a battery drill works just fine.
