MarkMcLain
- Clarksville, TN
If one google's "Grid Frequency Experiment", all results originate from newspapers or TV outlets. So far, there's little info besides, 'your clock may not be correct anymore' or more in that vein.
Is this a joke or is there any concrete info available that details the limits of variation in frequency? (that's besides the notion that if two generators are at two slightly different frequencies, and you 'parallel' them, the 'slower' one will shift it's load to the 'faster' one until frequencies are the same.)
For example, if Grid Frequency was allowed to drop from 60Hz to 50Hz, my Fire Pump would not turn at the 'design' rpm. Air Handlers that are older squirrel cage rotor motors would turn slower, pushing air a little less. Not sure what VFD's would do, but think they would turn their motor at the dialed in Hz/rpm.
Thanks for any info.
