How would you hook up a generator and PV with ESS so that both gen and PV with ESS can back up house?
Is there even a solution currently?
Solaredge says:
Unfortunately the only way to backup a home when the power goes out is with battery backup. Generators are not compatible at this time with our product.
Details:
I sold a 12 kW grid-tie-only system on a residence. SE11400US INV.
When i went to install.... they had a 22 kW GENERAC gen all installed. It feeds thru a 200A Generac ATS to back up whole house (200A).
That was an unwelcome surprise, given I planned a load side connection with the PV. (No supply side possible unless I replace MSP)
I finally worked around the gen thanks to amazing and patient expertise from a forum member here.
(A contactor disconnects INV output circuit when ATS switches to gen. e.g. in an outage)
Homeowner thinks it a shame no PV when grid out.
Is there manual way to switch to PV with ESS if ....say .....gen runs out of gas?
Solaredge says:
Details:
