- Massachusetts
The starting is not a problem, you have the Utility to take care of that. The PV just piddles along at a constant rate.
Except if the utility is down.![]()
I thought it is commonly understood that the PV's are designed to shut down when the Utility is down. So it is NOT a problem.:roll:
Take a look at the one line, the inverter is in series with the load, not parallel to it.
If you read the whole thread you will see the customer wanted to run the heat pump from the batteries so the inverter is not the same as just a grid tied inverter.
See post 14.
