Before I begin. I understand this is a big no no. Against code. For reasons. The reasons that I understand are the ground is meant to be a safety if a hot conductor were to touch a casing of a machine / device then a fault occurs which gets transferred from where the fault is all the way back to the bonding jumper at the source tripping the overcurrent device.
The question is this. How can I safely show somebody that using a ground as a neutral with no neutral at all present is incorrect and can potentially kill someone? What would it take to show them its not ok? Has anyone had to cross this bridge of explaining it to someone that is not grasping? Say scenario of 220V single phase with a couple of 120V devices (what the ground is for) inside.
