F faresos Senior Member Feb 21, 2024 #1 Hello, How you can attach a copper ground bar (2" X1/4") into building column steel without drilling or shot pins? Is there any approved way of doing this? Thanks,
roger Moderator Staff member Location Fl Occupation Retired Electrician Feb 21, 2024 #3 I have also used beam clamps.
infinity Moderator Staff member Location New Jersey Occupation Journeyman Electrician (retired) Feb 21, 2024 #4 Are you trying to bond the plate to the steel by mounting it? We use a stud welder to weld studs directly to the steel.
