- Illinois
- retired electrician
Typically the "commercial" cabinets are thick enough to engage two threads of a screw having 32 threads per inch.FWIW siemens says their (true) panelboard cabinets are 16 gauge. I dont know about their loadcenters.
The ones where you see the metal pushed out on the back side at the factory locations for grounding connections are the ones that you cannot drill and tap your own holes for grounding connections.
Note the the term "load center" is just a marketing term for a lower quality panelboard. The term load center is not found in either the NEC or the product standards for panelboards.
