1793
- Louisville, Kentucky
- Inspector
I have a topic on another section of this forum about H2-O heater and breaker. Now I would like to get the opinion of those on this portion of my problem.
In my neck of the woods in older installations we have a separate electric meter for the water heater. This is where my question comes into play. I have thought about just changing the FPE breaker in the 2 circuit MLO panel controlling this H2-O heater but I'm not happy about this option. The FPE is very expensive around $90.00 for a Double Pole. The ML panel is fed from this other meter and I’m concerned about the grounding / bonding. To help as much as I can, this small panel is fed with #10 in ?” EMT. There are only two wires in this conduit.
Does this second panel have any EG protection from the main service through the conduit connections?
Should I make a physical “tap” to the water ground from the main service panel for this panel, or come off the grounding bar with an EG to the water heater panel about a foot away?
I thinking of replacing this FPE with something newer and putting it on a main breaker panel. There is no room in the service panel for this water heater to be moved there.
I hope someone can make sense of this and offer a suggestion or two.
PS the HO will be making a big change to this house next spring and at that time we will more than likely go through a Service Upgrade.
Thanks
Thanks
