RSquirrel
- Watsonville, CA, USA
- Mechanical Engineer (retired/consulting)
For an upcoming underground feed to an outdoor CSED, PG&E (our local electrical utility) requires a grounding clamp with an integral conduit hub (the ground wire must be encased in rigid conduit - ½” in this case). For any of the clamps I have found (e.g. T&B/Blackburn JP-12), the smallest clamped water pipe size is ½” (0.84” O.D.). I need to clamp to a 5/8” ground rod, so the smallest listed clamp will not engage with the rod’s diameter. Can anyone suggest a specific grounding clamp to accommodate a ½” RMC conduit and a 5/8” ground rod?
