Ground conductor sizing
hhsting
Glen bunie, md, us
Junior plan reviewer
Attached sketch i have incoming poco conductors into Fire pump ATS/controller/disconnect all in one.
Between the Fire pump ATS/controller/disconnect all in one and the Fire Pump the ground cable is provided by the contractor and so is the phase conductors.
How does one size the ground cable between Fire pump ATS/controller/disconnect all in one and Fire pump label (1) in attached sketch?Which Article and section? Looked in 695 but did not find
As Fred said, it's in 250. If you can't find it you should find some code classes in your area to help you
