We have recently been asked to perform ground continuity checks on all of the motors here at our plant. I know the correct way of performing these checks is to string out a spare wire from the MCC to the motor and attach the one end of the spare wire to the motor frame. You can then go back to the MCC and check for continuity between the other end of this spare wire, and the ground bus thus proving the continuity of the EGC to the motor as the return path.
Somone recently came up with the idea of rather than using this extra spare wire, to simply lift the existing EGC wire off of the motor and then check continuity between the end of the EGC and the motor frame. His idea was that you could prove the continuity of the EGC by using the building structure to pass the test current back to the MCC and then back through to the end of the EGC. This would obviously require that the motor and everything in the building was bonded.
Has anyone ever heard of this method or know if it is a correct method to use?
