DavidTu
- Seattle, WA
Usually used Greenies but decided to try ground crimps (in this case #310 sleeve by GB). I used a Klein crimp tool's non-insul crimp, which has a small (sharpish) nib that seems to damage the wires. I did a test and cut open a sample crimp and found that the nib had compromised the wire and led to easy failure by moving the wire a bit. What tool should I be using and/or what technique will avoid the trouble?
I wanted to use these for multigang boxes as I prefer not to loop device to device w/ one pigtail and it seems like good use of the existing egc's w/o having to splice in multiple pigtails.
