ground dectors for delta systems 480 v ref forum june 2013 transformer neutral
we had many delta systems at naval station they were made up with 3 light bulbs 3trasnformers 480/120 some were connected delta pri. grounded y sec and a pushbutton to lift the ground (lamp test). or ungrounded y pri same sec connection. other were 3 240 volt meters or 1meter with a selector switch.
If you just wanted to add comments you should have posted to the existing thread, unless it has been closed. If it was closed you probably should have provided a link to the thread or mentioned a little more about it before commenting.
Otherwise - what is the question?
Welcome to the forum:)
