Mike373
- California
If the service for a building has a 2000 amp, 277/480 volt 3-phase GFI protected main breaker installed, will a 2000 amp, 277/480 volt meter main that is downstream also need to have GFI protection? I am not sure why you would install redundant GFI protection, but that is what an engineer is insisting on. Any code references would be much appreciated.
Thank you,
Mike
Thank you,
Mike
