PE (always learning)
- Saint Louis
- Professional Engineer
I've got an electronic trip 250 amp breaker at the switchboard that has both phase and ground fault settings. This breaker is protecting a 75 HP motor at 480V with a FLA of 96A. My question is: What should I set the ground fault pickup and ground fault delay time at? The ground fault pickup ranges from 50 to 250 amps and the ground fault delay ranges from .05 to .8 seconds
Typically on the phase side my settings are high to avoid the motor inrush, but what is best practice on the ground fault setting?
Any advice appreciated
