- Illinois
- retired electrician
Looking forward to reading your Public Input for the 2029 code.Ok, so maybe the code should trigger on
"rooms with conductive floors, including but not limited to concrete, with exterior doors leading to grade level".
Someone used EV charging as the "out the window" example, that's all. If you have an EV capable house the barrier is lower to get a proper
EVSE circuit which will be off except when in use.... no live cord out the window needed.
A very rare example as compared to running power tools or other outside equipment using a cord plugged into a receptacle in the garage or accessory building.
