ItsHot
- A little piece of heaven!
I am in the middle of a job that the plan calls for me to locate outside of a building the "ground loop". Then install a isolated grounding conductor from this sensitive piece of equipment to the ground loop. My question(s) Normally is the ground loop for roof-top lightning arrest system? If the equipment requires an isolated ground you have to have a separate isolated ground system.(?) I think the need for an isolated ground is why they are asking to locate "ground loop"?? Can you ground to a lightning systems ground???
