speedexracer007
What is the minumum size ground wire that can be used to ground a group of 12 - 4" EMT Conduits when they are stubbed into the bottom of an open cabinet. The emt conduits were changed over from PVC and rise up into the bottom of the cabinet. The size of the equipment grounding conductor is
600mcm. Can a smaller wire be used to bond or ground the conduits together or do I need to bond all of the pipes with the 600 MCM ground wire.
