buzzlectric
- Iowa
On a CNC,Injection Molding Machine, do all ground conductors have to go to the same lug on the machine or can you just attach to the steel frame of the machine with the ground rod conductor?
Just out of curiousity, why are you installing ground rods?Originally posted by buzzlectric:
we are not bonding junction box's, just installing ground rods. We don't blow mold, so i doubt you have been here.
In this case it appears the plant is adding ground rods. it's not clear the manufacturer called for them, nor why they would.Originally posted by bphgravity:
If the manufacturer requires a ground rod, regardless of why they think they need one, wouldn't it be required to be installed?
Many of the generators I see being installed today are not connected as SDS's yet the manufacturer places a lug on the frame and calls for a ground rod.
