hendelec
- Lilburn, GA
I have customer that is building a 24' x 24' wood frame building for his wife to use for her large crafts hobby. It is a wood frame structure built on a concrete foundation with wood floors, walls & roof. Nothing in the structure is metal. The building is 10' away from a detached garage (24' x 30') with it's owns 200 amp metered service from the local EMC. The garage is an all wood structure built on a concrete slab. I had planned to use a 60 amp feeder and a 100 amp sub panel with 6 branch circuits to feed the new building. The building will have 2 ceiling fans, 3 lights 24 recepticals. 1 out door GFI outlet and a 220v AC/heat thru the wall unit. There will be no bathroom or water piping of any type. This job is being inspected by a rural inspector that is demanding I drive ground rods for the new sub panel. The new feeder will be less than 50' from the existing service run in PVC conduit. Article 210.8 is a little confusing but seems to only require a new ground rod if bonding new water lines and metal building framing etc. in new building. He also wants all branch circuits too be GFI protected. l know the outdoor recepticals needs GFI protection but I am baffeled by his demands on the indoor recepticals . I can't find a Code Handbook newer than 2005, I moved a year ago and can't seem to find my new code book a the moment, still have many un loaded boxes............
