Ground Rod Sledge
SDS definition
SDS definition
Adapters are made for SDS impact drills for driving rods. They take all the fun and blisters out of hitting yourself with a sledge hammer and are quicker.
Or make an adaptor yourself with an old SDS drill bit. Cut off the shank and weld a nut on to form a cup for the rod.
With the drill chuck locked it just gives the impact blows and drives the rod in.
SDS (Shock Dampening System) is a type of impact drill not a make. You will have to find US manufactures on line or ask at a tool store.
Your UK definition of SDS may be different than ours:
http://www.technologystudent.com/pwtol/drill4.htm
What kind of rotary hammer drill do you have?
I have an SDS/SDS Plus and can't find an adapter for driving rods for it. Most of the ones I find are for, I think, the SDS Max which has a different shank.
I know that I can cut off an old chisel bit and weld an adapter to it but not sure if my drill has enough power to drive a rod anyway.
I don't have an SDS type but rather a spline drive type. Mine is a Milwaukee but others have same system that use same bits.
This is the type I have that works well with ground rods:
