Electron_Sam78
- Palm Bay, FL
I still don't see it as being premises wiring just a piece of equipment that happens to have wiring within it and is powered by on board components. Your car is also a piece of equipment powered by on board components and has wiring within it.
And yes I know the NEC does not apply to an automobile in general.
I believe you mentioned earlier the portable generator - What in the NEC covers a portable generator? The portable generator itself is likely a listed product also. When you connect it to a premises wiring system is when NEC comes into play.
I don't see the NEC applying. Is it a good idea to provide a grounding electrode for it - maybe. If lightning strikes it does it make much difference if there is a grounding electrode or if there isn't one? I really doubt it. If lightning strikes a pole connected to a premises wiring system can a lightning strike follow that premises wiring to other structures? Definitely.
on portable generators one example is section 250.34 in which it implies that if the portable generators don't meet the two stated requirements, a grounding electrode is required.
whether or not you think a GE is needed isn't really the issue, it whether or not it's required by the NEC and it seems like we're not going to agree.
