Hello all,
Yet another fist time poster. I am an electrical supervisor for a contractor currently stationed in Iraq. For years now the common meathod of providing power to our servicmembers has been to lay out armored cables on the ground and hook them up. 99% of the time the armor has been cut off at both ends, no neutral to ground bonding at the main or any where else, and a ground rod driven at each living container. QAQC won't sign off on anything unless they see the ground rods. They truely believe that that is what keeps you safe. I have used everything even ohms law to show them that ground rods don't trip breakers or mysteriously send fault current into the ground. I would go bond every panel to help but then we all know what happens when that Hummer drives over the cable and cuts the neutral. Running an additional ground wire or getting to the armor and trying to tie it in is not an option. Any suggestions on making this safer and Code articles to help educate QAQC and even my electricians.
Thanks guys and I look forward to the forum.
