I'm having a grounding issue at one of my customers homes. I installed a ground rod and ground wire to the water pipe to ground an old Pushamatic breaker panel that wasn't grounded. The cable company was having issues with there #10 ground wire melting when it was tied to the metal casing of the service before I installed the ground rod and water ground. This is creating a humming noise on the home owners flat screen TV. I checked all the neutral connections in the panel and they are tight along with each voltage phase to phase (240v) and phase to ground (120v) appear to be normal. I've noticed a faint spark when I removed ground wire from the ground buss in the panel. I'm at a loss as far as what to check next? Utility problem? Grounded hot wire somewhere in the house? Cable company issue? Any ideas?
