Alwayslearningelec
- NJ
- Estimator
How many of you guys would not run the ground and use the conduit as the ground? Or what would determine( besides spec) whether or not you run the ground?
Hear here. I would be very reluctant to spec "no EGC" unless all the conduit connections were compression type. Even then, box connectors don't instill a lot of confidence.... "The ... little dimples in the pipe ... seem a little wimpy. ...
As someone who has installed thousands of both types, and just as importantly, someone who has demoed almost as many while working on remodels I can say with all certainty that set screw type fittings are better than compression.Hear here. I would be very reluctant to spec "no EGC" unless all the conduit connections were compression type. Even then, box connectors don't instill a lot of confidence.
I almost never pull a green unless it's required.How many of you guys would not run the ground and use the conduit as the ground? Or what would determine( besides spec) whether or not you run the ground?
Amateur indeed.My amateur take on this is that it's a belt-and-suspenders kind of discussion. The screw connections making little dimples in the pipe to hold things together and make the connection (ignoring the pipe touching the fitting) seems a little wimpy.
Arguments have been made that in earthquake territory the wired ground would stay attached even if the conduit pulled apart.
Unfortunately steel supports, steel framing are not approved for a ground path.Amateur indeed.
Let's think about this belt and suspenders for a bit. I've got steel conduit tied to steel supports that are anchored to steel framing. Even if half the fittings were left loose on purpose there is still continuity back to the panel and a little wire in the pipe isn't making anything better.
A bigger trick would be trying to isolate a piece of conduit from ground. It's near impossible.
This whole mentality that is based on nothing but an idea that a green wire makes the world safer is what led me to come up with the term Cult of the Green Wire. They have a grip on the electrical world that is impossible to escape.
I didn't say steel framing is approved or not approved, the reality is it's there.Unfortunately steel supports, steel framing are not approved for a ground path.
If you do commercial, you have a spec that call for grounds nearly 100% of the time. How do you get away with it?
I agree with you. I think part of it is how much press it gets.I pretty much never pull a wire egc. Fortunately, I do mostly "design/build" type of work so I can save the client from inadvertently wasting their money on a wire egc.
I'm not sure how or when bonding became this absolutely critical aspect of an electrical system. It's become just about all anyone cares about and we seem to need these layers of redundancy. Sure bonding offers a measure of improved safety, but not nearly commensurate with how it is treated.
No they are not approved, but are still very effective if your green wire fails or your raceway comes apart.Unfortunately steel supports, steel framing are not approved for a ground path.
I have to agree there are many that just follow the leader and don't really learn all the technicalities of why things are the way they are or how they actually work.I agree with you. I think part of it is how much press it gets.
I also think part of the reason people fall so easily into the claws of the Cult of the Green Wire is a basic lack of learning about the electrical trade....I may not really understand what makes that motor spin or how this lighting ballast works, or what the XO on the transformer is for, or whatever, but one thing I know is I can put a green wire everywhere possible and know that I am doing a great job.
A loose set screw or compression nut is installer fault. I was working on something the other day and a bonding jumper to a box had a loose bonding screw to the box, and have many times seen poorly made up wire nut type connections as well - so mistakes can and do happen even with wire type EGC's.
Most the broken coupling or connector situations I have run into likely could have been avoided with proper raceway support methods.
I see it all the time, open a box and there's a wad of green wires under a nut two or three will fall out as soon as you move wires around to do your work...... I was working on something the other day and a bonding jumper to a box had a loose bonding screw to the box, and have many times seen poorly made up wire nut type connections as well - so mistakes can and do happen even with wire type EGC's.
Absolutely.Most the broken coupling or connector situations I have run into likely could have been avoided with proper raceway support methods.
For us they get what they're paying for. If they do not spec EGC's in a metallic raceway they don't get them.
