masterelect1
- Baltimore
As per the plans, a small centrifugal 240v- 3ph -1hp is shown to be grounded to building steel AND back to the service. According to the design engineer, this is to eliminate static build up in the pump.
It seems to me that grounding the pump casing to building steel would be sufficient to eliminate static build-up and potential shock/sparking.
It does not seem correct that the Engineer would also want to ground the pump to the Electrical system.
Any opinions on this?
thanks,
John
thanks,
John
