Grounding a long run RV panel
My situation: 30 amp, 120/240v RV panel like this. Feed from a 30amp single pole breaker, in 200amp main distribution panel (panel is under the meter box, panel has ground and neutral bonded, panel has 200 amp main disconnect breaker), about 350 feet away with #1awg copper conductor and neutral, and #6 copper ground wire, through 1.5" sch. 40pvc
My Question: Should I treat this RV panel as a sub-panel; isolating the neutral and tying the ground to a ground rod? If not, why? Otherwise I would just get a receptacle without the breaker and wire it like an outlet. It just seems a long way to go for that ground wire back to the main.
Love this forum and value the generosity of the moderators and knowledgeable contributors:thumbsup: Thanks!:bye:
I am closing this thread, in accordance with the Forum Rules.
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
* This NEC Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
If you feel this action to be in error, feel free to contact me via PM to explain.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
