I was doing a job for someone in ohio, and I installed a 100a 240v subpanel in this guys detached garage that he is turning into a wood shop. Well when the inspector came to inspect it, she turned it down cause I did not drive a ground rod. I used direct burial cable in the ground, which she also stated that I only had to bury it 18". I found the code for direct burial cable (300.5) which says it must be 24" but I could not fine the article for the ground rod. But I know that there should not be a ground rod cause that would create a parrallel ground ... right?
