MannyBurgos
- Waukegan, IL
Hello all. I really need help with this one. I've been tasked with a somewhat of a different project for me. Owner has a 2 family dwelling unit. Both main panels are located in basement and inspector wants units#2 to be re-located to that unit since unit #2 has no access to basement. Meter sockets will stay in place but I do have to add a main disconnect next to Unit #1 panel to comply with grouping of disconnect rules. Here's where my trouble starts; inspector wants a ground rod at meter trim which is not a problem and also wants a GEC from main(s) to water meter. How can I accomplish an NEC compliant GEC connection from water meter to the service disconnects? Can I terminate lets say from units#1 panel grounded bus bar to units#2 panel grounded bus bar and then back to water meter? I should also note that both panels will be bonded with emt if that makes a difference. I just did it last week at another property and the inspector approved the job but I want to be sure I am indeed grounding this equipment properly. I have my doubts on some of my local inspectors... Thanks all
