hhsting
- Glen bunie, md, us
- Junior plan reviewer
Attached sketch I have 200A service disconnect which feed trough. The trough is tapped first conductors with wire equipment grounding conductor in metallic conduit go to utility meter to Disco #1 and second conductors with wire equipment grounding conductor in metallic conduit go to second utility meter to Disco #2.
Disco #1 and #2:
1. Should it have main main bonding jumper and neutral to ground bond?
2. Metallic conduit between utility meters and Disco#1 and #2 should it be bonded by supply bonding jumper or equipment grounding conductor? If not then which bonding jumper?
3. Should Disco#1 and #2 enclosure be bonded to equipment grounding conductor? Which code section is this if yes?
Disco #1 and #2:
