Chip Meyer
Please excuse me, as machines that I design are typically DC or gas powered. I'm a relative newbie when it comes to AC.
I've been asked to design a scissor-lift truck that is powered by a customer supplied power source of 480 volt 3-phase ungrounded delta. From what I understand, this is three wires, potential across any two wires is 480 Volts. I will be using this power to run a 480 VAC motor, and also be sending 480 into a transformer to get 120 VAC for a control circuit. My problem lies with safety and grounding.
How should I ground this unit for safety? Should I have anything on the source side of the transformer? Should I ground the motor in some way? Do I need a ground on the 120 V side of the transformer, if so, just ground one leg to the frame of the machine?
Any help would be much appreciated. I've got a schematic and wiring diagram of an old unit on the way from the customer, but I'd like to double check your ideas versus the original design.
Thanks
Thanks
