brian john
- Kilmarnock, Va
- Retired after 52 years in the trade.
I looked at a service today that utilizes a 12X12 trough, the neutral is mounted to the back box and grounded per the NEC, in the trough. There are 3 MCB panels each is fed from the trough with a PVC nipple, each PVC nipple has 3 phase conductors and a neutral, in the panel the neutral bonded per NEC.
Should there be separate grounding conductor in the PVC nipple?
