tganz96
- Dallas , Texas
I am insatalling a new system which consists of 2 cabinets which have PLC's ,HMI's and Drives in each. One of them is built by anOEM and the other we did in house.
Cabinet A from the OEM and cabinet B from us has 4 conduits between them and are about 170 feet apart. We have 2 ethernet cables between the 2 cabinets and a switch in each to comm between a compact logix in our cabinet and a micrologix 1400 in the OEM cabinet.
We have 24 volt dc wiring between them to interlock the estop system. Should I connect a ground between the 2 cabinets or not and why? the OEM panel is fed from an Iline panel borad and our cabinet is fed from a MCC bucket and the MCC is fed from the same Iline panel board as the OEM panel.
I am just not sure what needs to happen with grounding between the 2 systems.
