Jerry Dunford
New member
- Urbanna, Va.
I have been out of the Electrical industry for 10 years or so, and I knew that in 1999 NEC, it required that when a 3 wire single branch circuit feeder with equipment ground, installed in non-metallic conduit or direct burial, that is supplying a sub-panel in a separate building, that a driven grounding electrode was required, as well as the neutral be bonded to the enclosure and to the grounding conductor in the separate sub-panel. I have since read that this may have changed. Can the forum provide some clarity to the requirements for this in 2017.
Thank you,
from and old Electrician coming back from the dust bin.
Thank you,
