I am inspecting the electrical system of an older home, of which the owner does not necessarily want to re-wire, but nevertheless I want to provide earthing and bonding to make the electrical system as safe as possible. This in an older Victorian-era home with many rooms. The distribution consists of two main panels, and a system of 5 sub panels throughout the premises.
I am designing a good grounding system in the main distribution section following the guidlines of the NEC. It is the sub panels that I have some confusion on where to go.
The sub panels throughout this home are fed with 3 wires (2 hot conductors, and a neutral). No third grounding conductor was pulled. If there is a fault imposed on the chasis of one of these panels (or any other apparatus supplied by these panels), there is no path to clear this fault back to the source. I realize that the simplest way to solve this dilemma is to run a ground conductor from these panels back to the established ground at the main distribution system, but this may not be practical due to the architecture of the house.
My question is: Can I bond the neutral to the case of the sub panels to establish a path to ground? I realize that this is not acceptable under normal circumstanses, but in this case I cannot find any other method of grounding the equipment in this facility. Are there exceptions to the code in this circumstance?
Ed Battle
Ed Battle
