Billy B
- Northern Va
We are having and interoffice disagreement/discussion regarding the code requirements for the subject issue.
My position is that a grounding conductor is required as per articole 250-30 and bonding is required to the NEAREST interior metal water piping as per 250-104(a) 4 with both conductors connected at the SAME point in the transformer to the XO terminal.
Rather than describe the other opinion which I am not sure I even understand, can someone please tell me if the above codes and interpretation is correct? Or advise otherwise.
trans is a 277/480 pri 120/208 sec
Thanks,
Bill
Thanks,
Bill
