I recently installed a 100 amp sub panel at my house for my pond equipment. I have 3 pump motors outside. An irrigation pump, an aeration pump and a jet pump down by my creek. Now my question is, do I need to do more than just run a ground wire to each pump? Do I need to drive a ground rod at any of them bonding them back to the equipment ground ran from the panel. The pond is going to be used for swimming and fishing. Just want to cover all my bases. Theres no wire mesh around the pond. The jet pump is 450' away so I am going to be setting a disconnect down by that pump. The other 2 pumps are about 4' behind the panel. The sub panel is outside by my pond.
