Hi, I've been replacing 2 wire receptacles ckts w/ 3 wire receptacle circuits for use w/new PC's in residences.
What I'd like to know, for the sake of installation time is, does installing a GFCI w/ no equipment grounding (bonding) conductor attached to it, affect the operation of the PC?
Even w/the absence of a grounding (bonding) conductor connected to the GFCI, I do understand that the GFCI will still open any line-to-case faults of anything plugged into it.
Is there some electronic thing going on within the PC that requires them to be connected to a 3 wire receptacle?
