LAYMAN JOE
I have a new building with two tenants. (2) 400 amp fused disconnect switches mounted outside 10' apart. One disconnect feeds one tenants panels and the other feeds the second tenants panels. This is all one 2000 sq foot building. There is copper water pipe and building steel available.
How would you ground and bond this system according to the NEC 2005. Specifically the wiring method you would use in bonding the two disconnects to the ground rod(s), cold water pipe, disconnects frame, and building steel ?
Thanks.
Thanks.
