LaROcque
- Phoenix AZ
- electrician
Need to double check if #4/0 ground wire from the grounded buried loop needs to have the 2 hole compression lugs torque when connecting them to the grounding bus bar.
Also, the other equipment ground wires that eventually get connected to the grounding bus bar also need lugs torqued?
This is in an industrial building and I can’t find anything in the specs indicating it’s required, but I think I need to do it.
Thank you
Thank you
