I got 1,884 ohms too, but that is just the inductive reactance. (2PifL) Don't you also have to include the resistance of the wire also to get the total impedance? 5 henry's is huge! It's like a 1 farad cap, ever see how big they are?
Also, I have always used 3.14 for Pi. Sam's lists shows 3.41?
The impedance of a series combination of 2 ohms Resistance plus 5 Henrys of inductance (at 60 Hz) is 1884.001 ohms. The resistance didn't make much difference.
Ed
[ October 29, 2004, 08:31 PM: Message edited by: Ed MacLaren ]
The equation I used (below) is based on the assumption that the 5 Henrys of inductance was "pure" (no resistance or capacitance) and therefore the phase angle is 90 deg.
You'll find voltage 90 deg. ahead of current across the coil. Your right about that. Here's the thing with the resistance. Although it doesn't have reactance it does have a phase shift of zero and is calculated in the same way as inductance and capacitance. The impedance value is a result of all the reactances and resistances that affect it.
