Andres Arias
PV Solar engineer
- New York
- Electrical Engineer
Hello everybody.
As far as I understand, the grounding conductor should be connected inside the panel before leaves the panel, right in the bushing installed in the knockout, as presented in the picture attached "Grounding cond connected", however I have seen that some panels have their grounding conductors not connected in the bushing of the knockout (see attached "Grounding cond no connected").
Question: Which of the two cases is valid for the grounding conductor inside the main service panel, in such a way that the electrical inspection does not fail ?
Thank you
Thank you
