igilmore
New member
- Granite Falls, NC, USA
My question is where the equipment grounding conductor, located within a metal conduit with current carrying conductors in a PV output circuit, will ground the equipment that is the metal conduit? If the conduit enters inside a building 690.31(G) will the conduit be grounded by the EGC at the point of penetration or where the EGC meets the grounding terminal in the accessable inverter?
