planas said:What section of N.E.C. apply to this subject?. What bonding conductor size ?. Please need help.
hardworkingstiff said:I found a NFPA document (back in the early 80's) that addressed this issue. I don't remember which one, but the basic idea was two ground rods on opposite ends/corners of the tank. A number 8 wire from the tank to the ground rods.
After looking in NFPA 30 and 30A, I believe you want to review NFPA 77.
petersonra said:The OP used the term "bonding" rather than grounding.
hardworkingstiff said:Oops, so they did. Thanks Peter!
Edit: Well, the title uses "grounding" and the subject field uses "bonding".
