To conceal the System Ground from the plate, I had run the cable into the wall and was wondering if there are any "inductive/choking" issues during an fault current, if I run it into the enclosed line side of the combination panel mounted to the back of the meter base, then through the steel nipple that connects to the meter base in order to connect to the common/neutral ?? Thanks again!
