Should the grounding electrode conductor that connects a ground rod or triad ground system to the main service ground be installed in conduit when routed below grade OR should the conductor (assuming it is bare) be routed so that it is in contact with the earth? If in conduit, does it matter if the conductor is covered, insulated or bare?
