OK I must be board to come back and keep trying. :roll:
You should probably start a new thread for your topic. Threads are not expensive.
Oh yes you are shaking things up and must be silenced. :roll:
And I see no inconsistency, not one bit. And my view has nothing to do with the status quo.
The conductors that are EXPECTED / REQUIRED to be part of the GES have to be sized per 250.66
not EXPECTED / REQUIRED to be part of the GES have to be sized per 250.122
Only if you choose to ignore the NEC requirements contained in 250.50
Again, the EGC between separate buildings does not perform the same function as the GEC inside a single building.
It is that simple.
