Sthome25
- Coatesville, PA
- Electrician
I have an odd situation. I will be updating a service that is located in the center of a steel bridge. The service (60 Amp) is for street lights and eventually some cameras. The AHJ (PennDOT) typically requires (2) 8' ground rods, but that doesnt work in the middle of a bridge. I am thinking that I can put a lug to the steel framing of the bridge at the service and at the end of the bridge, then set the two rods on the side of the bridge where the service is fed from (pole mounted transfromer). Any other insight on this situation would be greatly appreciated.
PA is currently using the 2014 NEC.
