I can?t make statements about other states but here in good ole NC the electrical inspector will inspect what my permit covers. Should there be some life issue with the other parts of the electrical system then the inspector will notify the proper person not me.
Case in point; I get a permit to do a change out for the AC unit. When the inspector comes to make their inspection of my permitted work he sees that the meter base is free from the building and swinging back and forth in the wind.
He will pass my work and post a notice that the meter base needs attention with a time limit to get it repaired before loss of power. He will not require me to do the repair before passing my permitted work.
Another; a plumber is replacing the supply water line to a building. He uses a metal water pipe for this replacement. A plumbing inspector will be the only inspector that sees this installation therefore no requirement to use this new pipe for an electrode. The plumbing inspector cannot require a plumber to install anything electrical nor can a plumbing inspector say anything about the electrical.
Should the plumbing inspector go back to the office and report this to the electrical inspector just what authority will the electrical inspector have? He can?t force the plumber to bond this pipe as he is not an electrician.
